Manage Bulk Device Deployment Spreadsheets
You can access any successfully uploaded spreadsheets to view, edit, delete, and download them.
To manage bulk device deployment spreadsheets, expand the Device Manager slider and select Bulk device deployment. The OC Spreadsheet tab appears, listing all OC bulk spreadsheets successfully uploaded on the OCSDM.
The following information is displayed for each file:
| File name | The name of the spreadsheet. |
| Offline Config | The offline config associated with this spreadsheet. |
| Software Version | The software version associated with this spreadsheet. |
| Platform | The platform of the associated offline config. |
When you select a spreadsheet from the table by highlighting the row,
the following buttons are enabled:
| View | Displays a read-only version of the spreadsheet. |
| Edit | Displays an editable version of
the spreadsheet, allowing you to make and save changes.
Note: The OCSDM validates any values added or updated before updating the spreadsheet.
| Delete | Deletes a spreadsheet. The OCSDM prompts you to confirm before deleting. |
| Download | Downloads the selected spreadsheet. |
