Manage Network Functions and Devices
As of Oracle Communications Session Element Manager Release 8.0, the previous device nodes (used in OCSEM 7.x) that maintained the standalone or HA pair devices were replaced with the concept of a Network Function (NF). NFs are a network architecture concept used to describe entire classes of network node functions into building blocks that may connect, or chain together, to create communication services as defined by the GS NFV-MAN 001 - ETSI. In this context, a NF can be composed of one-to-many Edge devices. For example, a SBCbased NF can be composed of two SBC instances running as a HA pair.
Oracle Communications Service Provider Edge and Core Plug-in Product Category and Network Function Types
As of Oracle Communications Session Element Manager Release 8.0, the previous device nodes (used in OCSEM 7.x) that maintained the standalone or HA pair devices were replaced with the concept of a Network Function (NF). NFs are a network architecture concept used to describe entire classes of network node functions into building blocks that may connect, or chain together, to create communication services as defined by the GS NFV-MAN 001 - ETSI. In this context, a NF can be composed of one-to-many Edge devices. For example, a SBC-based NF can be composed of two SBC instances running as a HA pair.
The following table describes the product category and Network Function (NF) types that you can select for your Oracle Communications Service Provider Edge and Core Plug-in.
| Product Category | NF Type | Component Devices |
| SP Edge & Core | Device | The following standalone component devices
are supported:
| Device Cluster | High-Availability (HA) device pair of the component devices listed above. |
Add a Network Function with Devices
Use this task to add a network function (NF) with devices to the default Home group or a group that you created. Once the NF is added successfully, the Oracle Communications Session Element Manager plug-in is able to communicate with the devices in the NF.
Pre-requisite: If you are not using the default Home group to add an NF, you must specify a group for the NF.
Once you have added one or more NFs with a group hierarchy, you can manage them as described in the following sections.
Launch a Managed Device Login Page
You can use Oracle Communications Session Element Manager as a single source from which to access and manage multiple products. When you select a device and click Launch, the system communicates to the device and displays the login page.
Move a Network Function to Another Group
You cannot move the NF if it is locked unless you are the owner of the lock or an administrator overrides the lock. An error message appears in both situations. See Override a Locked Network Function section for more information about unlocking an NF.
Remove a Network Function
When you remove an NF, all references to the NF in Configuration Manager, Device Manager, Fault Manager, Report Manager, Route Manager, Security Manager and Performance Manager are removed.
You cannot remove an NF during a configuration update or if the NF is locked unless you are the owner of the lock or an administrator overrides the lock. An error message appears in both situations. See Override a Locked Network Function section for more information about unlocking an NF.Lock or Unlock a Network Function
You can lock or unlock an NF and its device(s) with the appropriate administrator permissions.
Other users are prevented from rebooting, updating or modifying the configuration or route sets for an NF when you lock it. Only users with granted override lock permissions can override your lock or the NF must be unlocked by you.Override a Locked Network Function
You must have the appropriate privileges assigned by your administrator to override a lock set on an NF by another user.Override a Locked Device
You must have the appropriate privileges assigned by your administrator to override a lock set on a device by another user.Reboot a Device
You must have the appropriate administrator permissions assigned to reboot a device.Synchronize System Alarms with a Device
If the NF has an HA device pair, when you synchronize one device the other device in the pair is also synchronized.
- Expand the Device Manager slider and click Devices.
- In the Managed Devices pane, click the device you want to synchronize with system alarms and click Admin, Synchronize alarms.
- In the Synchronize alarms dialog box, click Yes.
- In the Information dialog box that displays, click OK.
Manage a Device Configuration in a Network Function Device Cluster
When new device variables are added to an offline configuration (in Configuration Manager) that NF device cluster devices use, you must configure each device in a device cluster with its needed device parameters.
- Expand the Configuration Manager slider and click Devices.
- In the Managed Devices pane, navigate to an NF device cluster device and click Configure.
- In the Configure data variable for.... dialog box, enter the required parameter(s) for the data variables for which you are prompted.
- Click Finish.
View Network Function Information
Use the following sections to view and manage Oracle session delivery product NF information, which includes its devices and the way detailed and summary NF information is displayed for its device node(s).
View Device States and Columns
You can monitor a variety of information for devices by viewing the state of their colored, round icons, and by using the column information presented for each device.
Expand the Device Manager slider and click Devices. The system displays a device group hierarchy showing the group, subgroup, and the network function (NF) that contains the devices.
The following states of a device in the Managed Devices table indicate if it can be reached by Oracle Communications Session Element Manager:
- Green—The Oracle Communications Session Element Manager can reach the device and retrieve information about the device through SNMP.
- Red—The Oracle Communications Session Element Manager cannot currently reach the device (or cannot contact both devices in an HA device pair).
The following columns appear in the Managed Devices table:
| Name | The group, subgroup, network function (NF) and device that belong to each NF. The grouping structure of the NF and its device is determined by the Session Delivery plug-in. |
| Version | The full software release version, including patch number of the NF HA device pair or standalone device. |
| Platform | The device hardware platform. |
| IP Address | The device IP address. |
| Serial Number | (Hidden) Serial number of the standalone device or the primary device in an HA deployment. |
| Group ID | (Hidden) The group element ID. |
| Object ID | (Hidden) Internal database object ID. |
| Offline Configuration | (Hidden) The name of the offline configuration associated with a specified NF device cluster. |
| Synchronized Mode | (Hidden) This column describes when Synchronized Mode is enabled or disabled for a specified NF device cluster. |
| ScalabilityGroupId | (Hidden) The ID of the scalability group. |
| Activation Status | (Hidden) Check the device status in a cluster. If the device boots successfully, the Active status displays. If the device fails to activate, the Activation Failed status displays. |
Manage How Groups for Network Functions are Displayed
Use the buttons at the top of the Managed Devices pane to affect the display of hierarchical groups, NFs and their associated devices.
View Hardware Details for a Network Function Device
You can find the following component inventory data for a NF device, such as chassis, CPU, memory, and so on.
View Software Details for a Network Function Device
The following boot parameters are displayed for Oracle Communications session delivery product devices:
- The software image and where the image is booted for this NF device (on an external device or internal flash memory).
- The type of software entity being booted.
- Status of that software entity.
