PreviousJavaScript must be enabled to correctly display this content
Obtain Support Information
The
Oracle Enterprise Communications
Broker (OECB) allows you obtain
a pre-defined file containing information that support personnel normally
request.
Access the
Support
Information page. Click
System,
Support
Information.
On the
Support Information page, click
Support Information.
Click
The
OECB displays a
Progress message
box, which indicates the system is generating support information output. When
complete, your browser displays a dialog where you to decide what to do with
the support-info.log file.
Do one of the
following:
Follow the
dialog's instructions to select the application you want to use to display your
