Software Packaging
The P-Cz3.2.0 build image is labeled nnPCz320.bz. The image is compressed by the zlib software library and includes all software components needed to install and operate the Oracle Enterprise Communications Broker (OECB).
Note that you must obtain a license if you want to use TLS for media and signaling. You do not need a TLS license for SSH, SFTP, and HTTP operations. See "Add a License with the Set License Wizard."OECB software delivered
for virtual machines includes the following packages:
| Image Name | Description |
| nnPCz320.bz | Standalone compressed image - This .bz image
package is primarily used to load and operate the
OECB software as an
appliance.
You can also use the .bz image for existing virtual machines. Create your virtual machine according to specifications. Then copy this image to your machine ( /code), and point your boot parameters to it. |
| nnPCz320-img-bin.ova | Virtual Machine Template - Import to a virtual machine hypervisor to create the entire machine. |
