PreviousNextJavaScript must be enabled to correctly display this content
Add a License with the Set License Wizard
TLS is the only
software feature for which you need a license on the
Oracle Enterprise Communications
Broker (OECB). You must
obtain a TLS license before you can add it. To obtain a TLS license, you must
present the correct system serial number to
Oracle.
Go to
Configuration,
Wizards,
Set
License.
The
OECB displays the
Set
License dialog.
Copy the serial
number for your
OECB and contact Customer
Support by logging into My Oracle Support or calling Oracle Customer support to
make the request. Oracle replies with your license.
After you receive
your license from Oracle, enter your license in the Add License field in
Set License .
The system checks the license and, if correct, installs it.
If the license is incorrect, the system displays a error message.
