Limitations Removed
Oracle strives to improve the software and hardware with each successive release, which can sometimes modify or remove a previous limitation.
Number of VLAN Connections
The software no longer limits the number of VLAN connections to one. The software now allows up to four VLAN connections. See "VLAN Support."
