Unique HMR Regex Patterns and Other Changes
In addition to the HMR support it offers, the Oracle Enterprise Communications Broker can now be provisioned with unique regex patterns for each logical remote entity. This supplement to pre-existing HMR functionality saves you provisioning time and saves Oracle Enterprise Communications Broker resources in instances when it was previously necessary to define a unique SIP manipulation per PBX for a small number of customer-specific rules.
Manipulation Pattern Per Remote Entity
On the Oracle Enterprise Communications Broker, you can configure logical remote entities (session agents, realms, and SIP interfaces) with a manipulation pattern string that the system uses as a regular expression. Then the SIP manipulation references this regular expression using the reserved word $MANIP_PATTERN. At runtime, the Oracle Enterprise Communications Broker looks for the logical entity configured with a manipulation pattern string in this order of preference: session agent, realm, and finally SIP interface.
On finding the logical entity configured with the manipulation string, the Oracle Enterprise Communications Broker dynamically determines the expression. When there is an invalid reference to a manipulation pattern, the pattern-rule expression that results will turn out to be the default expression (which is \,+).
When the $MANIP_PATTERN is used in a manipulation rule’s new-value parameter, it resolves to an empty string, equivalent of no value. Even though this process ends with no value, it still consumes system resources. And so Oraclerecommends you do not use $MANIP_PATTERN as a new-value value.
In the following example, the SIP manipulation references the regular expression from a realm configuration:
realm-config
identifier net200
description
addr-prefix 0.0.0.0
network-interfaces public:0
manipulation-pattern Lorem(.+)
sip-manipulation
name manip
description
header-rules
name headerRule
header-name Subject
action manipulate
match-value $MANIP_PATTERN
msg-type request
comparison-type pattern-rule
new-value Math
methods INVITE
Reject Action
When you use this action type and a condition matching the manipulation rule arises, the Oracle Enterprise Communications Broker rejects the request (though does not drop responses) and increments a counter.
- If the msg-type parameter is set to any and the message is a response, the Oracle Enterprise Communications Broker increments a counter to show the intention to reject the message—but the message will continue to be processed.
- If the msg-type parameter is set to any and the message is a request, the Oracle Enterprise Communications Broker performs the rejection and increments the counter.
The new-value parameter is designed to supply the status code and reason phrase corresponding to the reject. You can use the following syntax to supply this information: status-code[:reason-phrase]. You do not have to supply the status code and reason phrase information; by default, the system uses 400:Bad Request.
If you do supply this information, then the status code must be a positive integer between 300 and 699. The Oracle Enterprise Communications Broker then provides the reason phrase corresponding to the status code. And if there is no reason phrase, the system uses the one for the applicable reason class.
You can also customize a reason phrase. To do so, you enter the status code followed by a colon (:), being sure to enclose the entire entry in quotation marks () if your reason code includes spaces.
When the Oracle Enterprise Communications Broker performs the reject action, the current SIP manipulation stops processing and does not act on any of the rules following the reject rule. This course of action is true for nested SIP manipulations that might have been constructed using the sip-manip action type.
SNMP Support
The Oracle Enterprise Communications Broker provides SNMP support for the Rejected Messages data, so you can access this information externally. The new MIB objects are:
apSysRejectedMessages OBJECT-TYPE
SYNTAX Counter32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"Number of messages rejected by the SD due to matching criteria."
::= { apSysMgmtMIBGeneralObjects 18 }
apSysMgmtRejectedMesagesThresholdExeededTrap NOTIFICATION-TYPE
OBJECTS { apSysRejectedMessages }
STATUS current
DESCRIPTION
" The trap will be generated when the number of rejected messages exceed the configured threshold within the configured window."
::= { apSystemManagementMonitors 57 }
apSysMgmtRejectedMessagesGroup OBJECT-GROUP
OBJECTS {
STATUS current
DESCRIPTION
"Objects to track the number of messages rejected by the SD."
::= { apSystemManagementGroups 18 }
apSysMgmtRejectedMessagesNotificationsGroup NOTIFICATION-GROUP
NOTIFICATIONS {
STATUS current
DESCRIPTION
"Traps used for notification of rejected messages"
::= { apSystemManagementNotificationsGroups 26 }
apSmgmtRejectedMessagesCap
AGENT-CAPABILITIES
PRODUCT-RELEASE "Acme Packet SD"
STATUS current
DESCRIPTION "Acme Packet Agent Capability for enterprise
system management MIB."
SUPPORTS APSYSMGMT-MIB
INCLUDES {
apSysMgmtRejectedMessagesGroup,
::= { apSmgmtMibCapabilities 37 }
Log Action
When you use this action type and a condition matching the manipulation rule arises, the Oracle Enterprise Communications Broker logs information about the current message to a separate log file. This log files will be located on the same core in which the SIP manipulation occurred. On the core where sipt runs, a logfile called matched.log will appear when this action type is executed.
The matched.log file contains a timestamp, received and sent Oracle Enterprise Communications Broker network interface, sent or received IP address:port information, and the peer IP address:port information. It also specifies the rule that triggered the log action in this syntax: rule-type[rule:name]. The request URI, Contact header, To Header, and From header are also present.
---------------------------------------- Apr 17 14:17:54.526 On [0:0]192.168.1.84:5060 sent to 192.168.1.60:5060 element-rule[checkRURIPort] INVITE sip:service@192.168.1.84:5060 SIP/2.0 From: sipp <sip:+2125551212@192.168.1.60:5060>;tag=3035SIPpTag001 To: sut <sip:service@192.168.1.84> Contact: sip:sipp@192.168.1.60:5060
Name Restrictions for Manipulation Rules
Historically, you have been allowed to configure any value for the name parameter within a manipulation rule. This method of naming caused confusion when referencing rules, so now manipulation rules name must follow a specific syntax. They must match the expression ^[[alpha:]][[:alnum:]_]+$ and contain at least one lower case letter.
In other words, the name must:
- Start with a letter, and then it can contain any number of letters, numbers, or underscores
- Contain at least one lower case letter
All pre-existing configurations will continue to function normally. If you want to change a manipulation rule, however, you are required to change its name if it does not follow the new format.
The ACLI verify-config command warns you if the system has loaded a configuration containing illegal naming syntax.
Please note that the software allows you to make changes to HMRs, including configuring new functionality to existing rules, as long as you do not change the rule name. This results in an important consideration surrounding HMRs with hyphens in previously configured rule names.
- You can reference stored values in new value names. (Recall that stored values may be rule names.)
- You can perform subtraction in new value names.
If you use a rule names with hyphens within the REGEX of new value names, the system cannot determine whether the hyphen is part of the rule name or is intended to invoke subtraction within the REGEX. For this reason, you need to use great care with legacy HMR naming that includes hyphens.
As a general rule, create new rule names that follow the new rule naming guidelines if you intend to use new functionality in those rules.
New Value Restrictions
To simplify configuration and remove possible ambiguity, the use of boolean and equality operators (==, <=, <, etc.) for new-value parameter values has been banned. Since there was no specific functionality tied to their use, their ceasing to be use will have no impact to normal SIP manipulation operations.
