PreviousNextJavaScript must be enabled to correctly display this content
Configure Loop Sensing for PSTN Calls
To prevent call looping, use the
next-hop-policy-condition
parameter to construct a policy for the default route that prevents the
Oracle Enterprise Communications
Broker (OECB) from sending a
call back to the previous hop when the agent does not respond.
Access the Policy
Entries configuration object.
Configuration,
Service
Provisioning,
Policy
Entries.
On the Policy
entries page, click
Add, and do the
following:
Name
Enter a name for this policy.
Description
(Optional) Enter a description of the policy.
Conditions
Click
Add, select
next-hop-compare-condition,
and do the following:
Enter a name for
this condition.
Select the next
hop compare mode that you want from the drop-down list.
