Registrar Configuration Fields
To configure the Oracle Enterprise Communications Broker to act as a SIP Registrar:
Access the SIP
Registrar configuration object.
Configuration, System Administration, SIP Registrar.
On the Settings
page, do the following:
State Select to use this SIP registrar configuration element. Domains Enter one or more domains that this configuration element will invoke SIP registration for. Wildcards are valid for this parameter. Multiple entries can be entered in quotes, separated by commas. Minimum Register Expiration Enter the expire time in seconds to be used in the REGISTER. Default: 300 (5 minutes). Valid values: 0-999999999 Policy Enter one or more policies that you want to use to alter the processing of routes to a destination with registered endpoints. Additional Target Group List additional targets for the SIP registrar. Fork Group Select a number from 1-100 for the fork group registrar endpoints. LST File Enter the file name of the Local Subscriber Lookup table to use for authentication and user lookups. Authentication Method Set the method for the registrar to use to authenticate incoming registrations. - Save the configuration.
