Add an ECB Sync Agent
ECB Sync requires you to specify at least one sync agent for the Oracle Enterprise Communications Broker (OECB) to peer with before the system can perform sync operations. Each OECB can peer with up to ten ECB Sync agents and each ECB Sync agent can peer with up to 10 OECBs.
- Configure the agents that you want to add as ECB Sync peers.
- Enable ECB Sync.
Use the optional
step in the following procedure to add more agents to ECB Sync.
