LST Runtime Execution
The LST is loaded on boot up when the configuration is appropriately set. Incoming messages thereafter can then be authenticated based on the credentials in the LST. If the Oracle Enterprise Communications Broker can not load an LST file, three things occur:
- The following log message is recorded at the NOTICE level:
LST [table-name] was not loaded - [filename] has error loading XML file
- The message stated above is printed on the GUI.
- A 503 Response is returned to the UA that sent the initial REGISTER message to the Oracle Enterprise Communications Broker.
