Multi-Hop Agent Ping
The Oracle Enterprise Communications Broker (OECB) ping function can test connectivity to endpoints that are not directly adjacent to the source OECB. This multi-hop ping capability requires that you configure special routes dedicated to sending SIP options pings to these targets.
To enable ping tests to targets that are more than one hop from the
OECB, configure routes that
have the string "ping:" in the
Called
number field. These routes also have a first agent towards the
target configured in the
Route field, and the
last agent toward the target configured in the
Destination
Agent field.
The system invokes these
ping: routes for ping traffic only. In addition, the
system prioritizes SIP signaling traffic over
ping: route traffic.
The following table shows an example of a multi-hop ping route.
| Source Agent | Calling Number | Destination Agent | Called Number | Route | Cost | Policy |
| * | * | Target_Agnt | ping: | Adja_Agnt | 0 |
Having configured this route, you can initiate a ping to a target, or
configure agent pinging to
Target_Agnt by way of
Adja_Agnt.
You can also set up multi-hop ping recursion by creating multiple
ping: routes that specify the complete path to the
target. To create these paths, you can configure
ping: routes using the
Destination Agent and
Route fields to define each hop in a "ping path".
Based on the two route entries in the following example, ping attempts
to reach the device defined as
Target_Agnt follow a two-hop path:
- OECB to
Adja_Agnt Adja_AgnttoInterim_AgntInterim_AgnttoTarget_Agnt
| * | * | Interim_Agnt | ping: | Adja_Agnt | 0 | |
| * | * | Target_Agnt | ping: | Interim_Agnt | 0 |
The OECB uses an agent status, determined by OPTIONS ping, to validate all routes using that agent. Specifying an agent's status, including in-service and out-of-service, is the same for agents using either single or multi-hop ping. The system does not use routes to out-of-service agents for any signaling traffic.
