Route Policy
The Oracle Enterprise Communications Broker (OECB) includes a route configuration control called Policy that allows you to alter the behavior of routes. As the OECB assembles hops together to create a complete route, it considers and acts on the policies configured on each route entry.
You configure a route Policy from the Modify Routing entry dialog. The parameter values include:
Policy [ Deny | StopRecurse ]
The default setting is empty, which imposes no policy on the route.
The Deny policy in any resultant SIP routes to a destination prevents the OECB from forwarding a SIP request to the destination point in question. You can use the Deny policy to prevent sessions between two endpoints for policy or cost reasons. Consider this route entry.
| Source Agent | Calling Number | Destination Agent | Called Number | Route | Cost | Policy |
| Class_B | * | Protect_Agnt | * | Transit_Agnt | 0 | Deny |
The preceding route entry is designed to prevent calls passing through
the agent named
Class_B from reaching any endpoint behind
Protect_Agnt. This route entry may be installed as
part of one or multiple routes that could potentially reach
Protect_Agnt. The routing engine recognizes the
presence of this entry and rejects the call.
To expand upon the example, consider this route.
| Class_A | * | Protect_Agnt | * | Transit_Agnt | 0 | StopRecurse |
The preceding route configuration allows traffic to reach
Protect_Agnt as long as it originates througha the
agent named
Class_A.
The StopRecurse policy stops further attempts to forward a SIP request to a given destination if that route stops responding. The StopRecurse policy can prevent the system from forwarding calls on routes that are cost-prohibitive or might cause loops in SIP call flows.
For example, consider the scenario where an endpoint can be reached using two routes.
- Route 1: Agent_1 to Agent_2 (StopRecurse) to PBX
- Route 2: Agent_3 to PSTN
Route 1 uses a StopRecurse policy defined on the hop between Agent_2 and PBX. The OECB stops processing the call if Route 1 does not receive a successful response. This configuration can prevent calls initially targeted for Route 1 from using the PSTN.
