HMR Import-Export
Due to the complexity of SIP manipulations rules and the deep understanding of system syntax they require, it is often difficult to configure reliable rules. This feature provides support for importing and exporting pieces of SIP manipulation configuration in a reliable way so that they can be reused.
To Import HMRs, use the Upload link on the sip-manipulation list dialog, which is the first dialog displayed after clicking the HMR icon. To export, use Download.
Exporting
The SIP manipulation configuration contains an
export command which sends the previously selected configuration to the designated file. The syntax is
export [FILENAME]. The system compresses the file with gzip and writes it to the
/code/imports directory.
SIP manipulation configurations can only be exported one at a time.Exported data will look like this:
<?xml version='1.0' standalone='yes'?>
<sipManipulation
name='manip'
description=''
lastModifiedBy='admin@console'
lastModifiedDate='2009-10-16 14:16:29'>
<headerRule
headerName='Foo'
msgType='any'
name='headerRule'
action='manipulate'
cmpType='boolean'
matchValue='$REGEX("[bB][A-Za-z]{2}")'
newValue='foo'
methods='INVITE'>
</headerRule>
</sipManipulation>
To avoid conflicts when importing, the key and object ID are not included as part of the exported XML.
Importing
The import command imports data from a previously exported file into the currently-selected configuration. If no configuration was selected, a new one is created. The syntax is import [FILENAME]. Include the .gz extension in the filename. After importing, type done to save the configuration.
- Delete the object with the same key and re-import.
- Select the object with the same key and perform an import that will overwrite it with new data.
