PreviousNextJavaScript must be enabled to correctly display this content
Obtain Support Information
You can manually generate a file by way of the Web GUI that
contains troubleshooting information. You can save the file and send it to
Oracle Customer Support.
Access Support
Information:
System,
Support
Information.
In the
Confirm dialog,
click Confirm.
The system generates the file.
The browser asks you to do one of the following:
Open the file—Select
the browser and click
OK, select the tool and click
OK. The GUI displays the file.
Save the file—Click
OK. The GUI saves the file.
Click
OK.
The system downloads the file to the specified location.
