Runtime Routing with Policies in the User Table
You can apply a policy to the Oracle Enterprise Communications Broker (OECB) user table for more granular control over where a policy gets applied to runtime routing decisions.
Applying a policy to the user table provides more granularity than the routing table can provide because user table entries allow individual phone numbers and phone number ranges.
The OECB applies policies from the user table to the last hop on the route list specified in the routing table.
The system uses the policy applied to the called number from the user table.You can use policies from the user table and the routing table together. When used together, the system obeys the policy in the user table first and the routing table second.
When you configure a policy in the User database for a particular entry, the OECB applies the policy to all agents for that entry including any Additional Target Groups among those agents. When the session agent is a Session Agent Group, the OECB applies the policy to the session agent of that Session Agent Group.
- Add the policy to the OECB.
- Add the policy to a user entry in the user table.
