Alternate Translation Modes
As described in agent configuration instructions, a translation mode specifies the format required by that agent. The configuration normally applies to a PBX when it is the last agent in the path to the user.
This example implements a different configuration for PBX-BED, as follows.
| Hostname | Source Context | Number Translation Mode | Number of Digits | Prepend Prefix |
| PBX-BED | n-digit-dialing | 5 |
This configuration produces the following results.
| From | Dial String | Transformation | Result |
| acme.bedford | 54321 | +17815554321 | Call is directed to PBX-BED as a 5 digit number (54321) |
| acme.madrid | 10154321 | +17815554321 | Call is directed to PBX-BED as a 5 digit number (54321) |
| acme.berlin | 10154321 | +17815554321 | Call is directed to PBX-BED as a 5 digit number (54321) |
