PreviousNextJavaScript must be enabled to correctly display this content
SIP Authentication Query Configuration Fields
To configure the
Oracle Enterprise Communications
Broker to specify an alternate authentication field in a remote
database for the purpose of authenticating registration attempts:
Access the LDAP
Configuration object.
Configuration,
System Administration,
LDAP,
LDAP
Config.
On the LDAP Config
page, expand
SIP
Authentication and do the following:
Username Attribute
Enter the name
of the attribute where the digest username is stored in your LDAP database.
Default: sAMAccountName. (The standard Active Directory username attribute.)
Digest Hash Attribute
Enter the
name of the attribute where the digest authentication hash is stored in your
LDAP database. Default: orclDigestPwdAttribute. (A custom field populated by
the oidpwdcn password filter.)
