Accessibility Features
The following accessibility features are available in this release.
Keyboard Navigation
You can access GUI functionality using only the keyboard. Use the
following keys to navigate:
- Tab key: Move to the next control, such as a dynamic target menu, navigation tree, content pane, or tab in a page. Tab traverses the page left to right, top to bottom. Use Shift +Tab to move to the previous control.
- Up and Down Arrow keys: Move to the previous or next item in the navigation tree, menu, or table. Down Arrow also opens a menu.
- Left and Right Arrow keys: Collapse and expand an item in the navigation tree or a submenu.
- Spacebar: Activate a control. For example, in a check box, spacebar toggles the state, checking or unchecking the box.
- Enter: Activate a button.
Some functionality cannot be accessed through keyboard navigation.Microsoft Screen Narration and Jaws
This product is compatible with common OS's screen reader programs.
Microsoft Magnifier
This product is compatible with common OS's screen magnifying features.
