Configuration Tools and Behavior
The Oracle Enterprise Communications Broker (OECB) Web GUI provides the following tools for working with configurations. Some tools are located in the navigation pane and others are located at the top of the center pane.
The Configuration Tab Display
The following screen capture shows the locations of all of the Configuration tab controls.
Controls in the Navigation Pane
The navigation pane displays links to Configuration Wizards and Show Commands. (Descriptions are listed in the center pane.) The Wizards help you specify certain parts of the configuration and the Commands show you information about the configuration on the system.
Controls in the Center Pane
The controls located at the top of the center pane on a configuration page help you manage configuration objects.
| Save | Use to save the current configuration session. Upon Save, the system displays a prompt giving you a choice of whether or not to activate the configuration. If you do not activate the configuration, you can continue to make changes and Save again. When finished, you can save and activate all of the configuration changes. |
| Verify | Use to confirm that the configuration is valid before you save it. |
| Discard | Use to undo all configuration changes made in the current session. The system can only discard the changes that you saved. It cannot discard any changes that you activated. |
| Search | Use to find and display the current settings for the configuration you are editing. Enter the name of the configuration object. |
Controls for Multi-Instance Objects
The controls located at the top of a list of multi-instance objects help you manage the objects on the list. The following screen capture shows the controls.
| Add | Use to add another instance of the configuration object with one or more parameters set differently. |
| Delete All | Use to delete all
instances.
Caution: You cannot select a sub-set of instances and delete only those. The system deletes all instances, regardless of how many you select. |
| Upload | Use to upload a configuration file in CSV format. |
| Download | Use to download a configuration file in CSV format. |
| Search | Use to search the list of multi-instances for a specific instance. When you enter the name of an instance, the Web GUI displays it at the top of the list. |
The Wizards object in the navigation pane displays a list of configuration wizards from which you can perform, save, and activate selected configuration procedures for the Oracle Enterprise Communications Broker. You can launch the Wizards in Basic Mode and Expert mode.
| Set Boot Parameters | Specify the boot file and the boot parameters. |
| Set Entitlements | Set the number of sessions that a license entitles, and enable advanced features. |
| Set Initial Configuration | Configure a new system and reconfigure an existing system. Includes configuring High Availability. |
| Set License | Enter the license number for a feature. |
| Set Logon Banner | Customize the text on the Web GUI logon banner. |
| Set Time Zone | Select the time zone for the deployment. |
| Upgrade Software | Upload a new version of the software. |
Set Boot Parameters Wizard
The Oracle Enterprise Communications Broker (OECB) requires you to enter the necessary parameters to boot the system in your deployment.
You can set the OECB boot parameters from the Set Boot Parameters Wizard on the Web GUI in either Basic mode or Expert mode.
Set Entitlements Wizard
Use the Set Entitlements Wizard to enter the maximum number of sessions that your license allows.
- Note the session limit number from your license.
You can launch the Set Entitlements Wizard on the Web GUI in either Basic mode or Expert mode.
Set Initial Configuration Wizard
Use the Set Initial Configuration wizard to perform the initial configuration on an unconfigured system and to change the configuration on a configured system. During the configuration, you select the scope of configuration that you want to perform, define the boot parameters, opt to set a VLAN, and configure features such as High Availability (HA) and access to the Oracle Communications Session Delivery Manager (OC SDM). A valid license is required to run the Set Initial Configuration wizard.
Launch the Set Initial Configuration Wizard
- Unconfigured system. The system launches the Web GUI Set Initial Configuration wizard upon the first logon. When the initial configuration is complete, the system saves the configuration, activates the configuration, and reboots. The system does not backup the initial configuration of an unconfigured system.
- Configured system. From the Configuration tab on the Web GUI, click the Wizards button and click Set Initial Configuration. When the re-configuration is complete, the system saves a backup of the existing configuration, saves the new configuration, activates the new configuration, and reboots. The backup is stored in /code/bkups.
| Enable Web GUI: Yes or No | If you select No, you may continue using the Wizard to set the initial configuration until you reboot. After you reboot, the system no longer displays the Web GUI. If you want to enable the Web GUI in the future, configure the Web Server Config object from the ACLI. |
| Choose Web GUI Mode: Basic or Expert | When selecting Basic mode or Expert mode, the
decision is about how much control you want in the configuration process and
whether or not you want to use one of more of the advanced features and
settings provided in Expert mode.
| OECB Mode: Standalone or High Availability |
| OECB Role: Primary or Secondary | If you selected High Availability for
OECB Mode:
Unlike other OECBs, which provide 2 management interfaces and 2 media interfaces, the Acme Packet 1100 provides 1 management interface and 2 media interfaces. When configuring HA, the configuration dialogs for the Acme Packet 1100 differ from the other OECBs because you must create a second, virtual management interface. For creating the second management interface, the HA dialogs on the Acme Packet 1100 contain more attributes than the dialogs for the other OECBs. Regardless of the OECB model, the path through the Set Initial Configuration wizard to the HA dialogs is the same as described in this topic.Configure the System
The system requires an initial configuration of attributes, such as modes and IP addresses, before it can function in the network.
Use the Set Initial Configuration Wizard to define the attributes for the system. The system displays the Set Initial Configuration Wizard upon the first logon.
- Configure the system objects.
Set License Wizard
Use the Set License Wizard to enter the serial number for your license. You can use the Set License Wizard in Basic Mode and Expert Mode.
- Obtain the license, which includes the serial number, for the feature that you want to add to the deployment. See "Obtain a License" in the ACLI Configuration Guide.
You need the license number for the following procedure.
Set Login Banner Wizard
Use the Set Login Banner Wizard to add customized text to the log on page. You can use the Set Login Banner Wizard in Basic mode and Expert Mode.
You can customize the log on page by adding text to help the user. For example, Welcome to <company name> <business unit> <location> session border controller <device name>.
Set Time Zone Wizard
The system requires a setting for time zone.
You can set the system time from the Set Time Zone Wizard on the Web GUI. You can select a time zone or Coordinated Universal Time (UTC). You can use the Set Time Zone Wizard in Basic Mode and Expert Mode.
Upgrade Software Wizard
You can upgrade the system software with the Upgrade Software Wizard on the Web GUI. You can use the Upgrade Software Wizard in Basic Mode and Expert Mode.
Use the Upgrade Software Wizard to perform the following tasks:
- Check the system health before the upgrade
- Download new software
- Change boot parameters
- Reboot the system
The system requires a reboot after the upgrade for the changes to take effect.
Edit, Copy, and Delete Configurations
You can edit, copy, and delete multi-instance configurations by way of the controls that the Web GUI displays on each multi-instance configuration page. The edit and copy functions act only on a single instance of a configuration. The delete function can act on either a single instance or all instances.
To edit, copy, or delete a single multi-instance configuration, select the configuration and right-click. The Web GUI displays the edit, copy and delete menu.
When you click Delete, the system displays a confirmation dialog before performing the operation. When you click either Copy or Edit, the GUI displays the configuration dialog.
Caution:
You cannot select several instances and delete only those. The system deletes them all, regardless of how many you select. For example, if you select two of three configurations and click Delete All, the system deletes all three.Configuration States and Behavior
After you finish creating or modifying a configuration, you must save and activate the configuration before the Oracle Enterprise Communications Broker (OECB) saves the changes to the running configuration.
- Editing. The editing configuration is the version that you are making changes to from the Web GUI. The editing version is stored in the OECB volatile memory. The editing version cannot survive a system reboot.
- Saved. The saved configuration is the version of the editing configuration that the system copies into the non-volatile memory when you click Save on the Web GUI. Until you activate the saved configuration, the changes do not take effect on the OECB. The system does not load the saved, but not activated, configuration as the running configuration on reboot.
- Running configuration. The running configuration is the configuration that the system is using. When you activate the saved configuration it becomes the running configuration. Most configuration changes can take effect upon activation. Some configuration changes require a system reboot. On reboot, the system loads the running configuration.
- OK. All configuration dialogs display an OK button that saves changes to the editing memory. If you reboot before the next step, the OECB does not save the changes.
- Save. The Save button on the Web GUI toolbar verifies the configuration, displays errors, saves the current configuration to the last-saved configuration, and stores it on the OECB. The system displays any errors at the bottom of the Configuration page.
- Activate. After you finish making one or more configuration changes, OK and Save from the last configuration dialog that you need to edit at this time. The system displays the Confirmation dialog containing the Activate button. When you click Activate, the OECB activates all of the saved configuration changes and saves the new configuration to the running configuration. If you cancel the activation function, the OECB saves the configuration in a file and does not change the running configuration. You can continue to make changes to the configuration.
Configuration Error Messages
If you save a configuration that contains errors, the system displays the following error message: There were errors! Are you sure you want to activate the configuration?
The system displays a list of errors at the bottom the page. Click an error to go to the location in the configuration where the error occurred and edit the configuration as needed.
| Severity | Identifies the level of severity that the Oracle
Enterprise Session Border Controller assigns to the error. Valid values are:
| Message | Identifies the element field where the error, warning, or critical error occurred, and the reason for the error. |
| Object | Identifies the element and the field for that element where the error occurred. |
| Attribute Name | Identifies the attribute within the element where the error occurred. |
| Other | Identifies any other pertinent information relating to the error. |
Uploading and Downloading Configuration File Elements
The Oracle Enterprise Communications Broker allows you to upload and download files containing certain key elements of your configuration that are more easily managed separately from the overall system configuration. Such elements include:
- Dial Plans
- Dial Patterns
- User Database Entries
- Route Database Entries
- SIP Manipulation Rules
The corresponding dialogs for the items in the preceding list include controls for uploading and downloading files, depending on which action you choose. When you click the Upload button, for example, the system displays the Upload file dialog, which includes a Browse button. When you click Browse, the system opens a browse dialog, from which you can select the file that you want to upload. Download behavior is similar. The system performs the file transfer to the correct system directories in the correct format without requiring any intervention. The following screen capture shows an example of the Upload File dialog.
Using Tag Fields
The Oracle Enterprise Communications Broker provides a configuration element data field referred to as a tag. You enter information into the tag field for descriptive and grouping purposes. You can establish your own criteria for labeling configuration elements with these tags. Tag fields have no operational effect on signaling services.
The following configuration objects display the Tags text field:
- Agents
- Users
- Routes
You can enter any text that you want into the field and you can apply as many tags to a configuration object as needed. You can filter the element list searches using tags as a means of organizing these objects. Applicable element list search fields include a down arrow that exposes a tag drop-down list, from which you select the tag on which to filter the list. Tags have no operational function other than supporting this kind of filtering.
