Utilities
Skins
Settings
File Import Utility- Select the File Import Utility in order to import a file. Click on the load button below the template input box.
File Export Utility- File export utility can be used to export the document file on the system. The data related to the file would be displayed on the screen.
Skins can be selected in order to change the look and feel of the Corporate Access Module. Select a color and then save the settings. In the next login the new skin is saved for the user.
Settings
User is setup in FM for CAM at the time of first login, the user is prompted to fill email id, this is mandatory for CAM users and approvers.
