To view a list of approvals, click on the Approval icon. The list contains the login IDs and this can be checked against their approval or rejected status. Use the Approve/Reject option to approve or reject the visit.
The Search panel lets you search on Request Status and Visit Location as well as other personal details of the visitor. Visits can also be approved or rejected by selecting the visits and pressing the CTRL key, and then selecting the Approve/Reject option.
