Prerequisites
Prepare a new encryption key with 8 — 16 digits. This key can be generated using an external key generator software.
OHC Sender/Receiver (Shoreside) is not running.
Exit OHC WatchDog. If you did not exit the OHC WatchDog, it will restart OHC Sender/Receiver.
Close all FMS applications. All read/write access to FMS DB is not allowed.
Run FMS OHC Encryption Manager.
Select the Encryption Key tab.
Select a schema from the Connection drop-down list.
Enter the new key.
Click the Start button.
Figure 15-1 FMS Encryption Manager
Completing the Key Rotation
Restart the FMS shore Sender/Receiver.
Run FMS application and verify if PII data is viewable.
