Pre-requisites
There are the separate setup executables or installers for both the Sender and Receiver components. Both require pre-requisite in order for these are to be installed and run. The .NET Framework 4.6.1 or higher version must be installed before the setup executable or installers can continue as these are built upon its architecture.
