Ships Decode
This set up is needed to convert ships code from Polar to the equivalent FM codes. Also, it enables you to assign several sets of ships to different processing machines for load balancing. Some sections of the vessel decoding are for the main ResOnline application use only.
Figure 12-3 Ships Decode set-up
This figure shows Ships decode from Polar to the equivalent FM codes
