Customizing Statistical Analysis
The Statistical Analysis screen provides financial data in form of pivot grids.
  1. On the Fleet Management screen, select Reporting and Utilities menu, and click Statistical Analysis . Statistical Analysis screen appears
  2. On the Statistical Analysis screen, in the left navigation pane:
    1. In the Search drop-down list, under Ship/Cruise enter information in the given fields.
    2. Under Demographics enter Nationality, Age-Group and Gender.
    3. Under Date Range, enter Start Date, End Date, and Fiscal Year.
    4. Under Classifications/Departments, in Main Department and Sub Department fields, enter Group, Classification, and Department details.
  3. Drag and drop the individual items from Ship/Cruise, Demographics, and Date Range into Passenger Revenue Analysis pane. The data are displayed in the columns.
  4. On Statistical Analysis screen, click Department Analysis. Department Analysis screen is displayed in the right pane.
  5. You can rearrange the columns and rows in the Department Analysis pane.
    All the selected data in the various grids are visible in the form of graphical representation at the bottom of the screen.
  6. To collapse or expand a list of Departments or Classifications, right-click anywhere in the Classification result shown in the Department Analysis pane, and select Collapse All or Expand All.
  7. Select values in the grid and right-click on the selection to export the details to other formats for example, .XLS, HTML, or PDF.
  8. To apply Filter Editor, right-click on any column header, and click Filter Editor. Filter Editor enables you to include a criteria filter.
  9. In the Settings drop-down list:
    1. Select Public or Private settings.
    2. Insert a template name and select Save Current.
    3. Select an existing XML template in the Load From drop-down list.
    4. Click Delete Current to delete the template.
      The Private settings enable only the logged in user to view this template. The Public settings shows the template to all users.
