Oracle Hospitality Cruise Fleet Management (FMS) is a shore side solution that provides business analysis capabilities using various modules with vast integration capabilities to property management systems, paperless analysis, reservation data interfaces and reporting applications.
Purpose
These Release Notes provide a brief overview of additions, enhancements and corrections implemented in this Fleet Management release.
Audience
This document is for the technical specialist, support teams and customers.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
| Date | Description of Change |
August 2019 |
Initial Publication |
March 2022 |
Updated content to HTML format |
