The content below is a list of the features and updates for the FMS 9.1 release.
Authentication has been added in the FMS Security Service for the FidelioBK password and the KEK Key retrieval. Also, login authentication has been added to all FMS components.
A new component has been added: The Security Server Windows Application allows for the rotation of KEK Key and FidelioBK passwords.
The batch level tracking of records is a new feature for Sender and Receiver. For better troubleshooting, you can track at record level for the Sender/Receiver data transfer.
Sender/Receiver uses the MSMQ with Active Directory integration. It enables the MSMQ to encrypt messages transferred between FMS Sender and FMS Receiver. Also, it checks the authentication to clarify that it comes from a trusted source.
For data transfer between the shore side and the ship side, you can use the MSMQ Active Directory mode for all the host machines. Note that both must be on the same domain.
Interfaces running on a ship use the ship side security service.
