This chapter describes the enterprise server operating systems, databases, and devices supported with the Fleet Management System.
Supported Enterprise Server Technology
Fleet Management supports the following operating systems:
Microsoft Windows based Operating Systems
Microsoft Windows Server 2012 R2
Microsoft Windows Server 2016
Fleet Management supports the following databases:
Oracle Database 11g / 12c
Oracle Full Client 12c
SPMS/FMS Version Compatibility Matrix
ResOnline is cross compatible with the Oracle Hospitality Cruise Shipboard Property Management System (SPMS), also working with SPMS 7.3 and SPMS 8.0
Table 2-1 Compatibility Matrix
| SPMS/Sender Receiver Version | SPMS 8.0 | SPMS Old |
Sender/Receiver 9.1.0.0 |
Compatible: Use Sender/Receiver 9.1.0.0 |
Compatible: Use Sender/Receiver 8.2.2.1007 [Use settings CompressionType = OLD] |
Sender/Receiver 8.2.2.1006 |
Not Compatible: Upgrade FMS old to FMS 9.1.0.0 |
Compatible:- |
Prerequisites
The application requires the use of FMS Security Service. The Oracle Hospitality Cruise Fleet Management User Guide Release 9.1 contains additional details.
New FidelioBK keys are required. Use the Database Password Manager to update the keys.
