This topic explains the prerequisites for Fleet Management System (FMS) installation and upgrade.
Below are the minimum system requirements for each server type. We strongly recommend that you refer to the Cruise Compatibility Matrix at Oracle Help Center for the latest supported Operating System and Database version.
Operating System: Microsoft Windows 2012 R2 / Microsoft Windows 2016 Standard / Microsoft Windows 2019 Standard / Microsoft Windows 2022 Standard
RAM: 32GB
Hard Disk Size: 1TB
Oracle Database version: Oracle 12c (12.2.0.1 64 bit) with Unicode (AL32UTF8) / Oracle 19c
Database Configuration:
The Database character set can be set to Western or Unicode. However, you must ensure that SPMS and FMS Database character set are configured the same to avoid data discrepancy. For example, if the character set is set as UTF8 in SPMS Database, then it has to be the same in FMS Database.
Similarly, the Database table column type must be configured the same in both the SPMS and FMS. For example, if the type NVARCHAR is used, then both the SPMS Database and FMS Database must be the same.
RAM: 16GB, Hard Disk Size: 512GB
Oracle Full Client: 12.2.0.1 32 bit / 19c
Microsoft .Net Framework: Version 4.6.1. See Microsoft .Net Framework Versionfor more information.
Operating System: Microsoft Windows 10 Enterprise Build 1607 (x64, Bare OS) / Microsoft Windows 11 (64 bits) /Microsoft Windows 2019 Standard / Microsoft Windows 2022 Standard
Microsoft .Net Framework: Version 4.6.1, see Microsoft .Net Framework Version.
Java Runtime Environment (JRE): Version 8
You must have JRE installed on client running the FMS Database Updater applicationAll the FMS Sender / Receiver host machines must be in same domain when transferring the data over MSMQ with the Active Directory integration.
The IIS Server machine and the FMS Client machine also must be on the same domain to authenticate the login credentials in Active Directory login mode.
