The first step in the Loan origination process is entering credit application data into Oracle Financial Services Lending and Leasing Application. The Simple Application Entry screen enables you to specify information from the credit application into the system and request a credit bureau report.
This chapter explains how to use the Applications screen to specify and validate a credit application.
There are four main steps in entering an application
You can also enter credit application data into Oracle Financial Services Lending and Leasing Application using the Fax-In container. For more details, refer to ‘Application Entry using Fax-In’ section.
Once the basic details are entered, the user has to check whether the application pre qualifies or not. Once the pre-qualified edits are satisfied, click Submit in the Application screen.
When finished, Oracle Financial Services Lending and Leasing checks the application for completeness using a predefined set of edits. These edits search for errors and warnings based on your system setup. Status change of the application can be determined by the credit bureau and scoring model of the application. The prescreening checks ensure that automatic credit bureau reports are pulled only for applications which meet set criteria, thus saving cost.
After an application clears the edits check, click Process Application in the Applications section. The system begins the processes of prescreening the application and pulling a credit bureau while you can begin entering the next application in your queue.
To enter a new application
The Recreate Instance button appears only when the BPEL parameter is YES.
For field description refer Applications of the Underwriting chapter:
You can pre-fill the applicant information if the same applicant details are already captured as a prospect in the Sales Lead screen. To do so, select the sales lead number in the drop-down of ‘Lead #’ field and save the Application details. The ‘Copy Lead Details’ button is enabled in the Applicant section below. Click on it to auto populate the Applicant details.
After entering the basic details of the applicant like identification and demographic details along with the address, employment, assets, liabilities and other income information and requested details, the user has to check whether the application pre-qualifies or not by clicking Pre-qualify Application button. This is governed by a set of Pre-qualification edits.
If pre-qualified edits are satisfied, the status is changed to NEW-PREQUALIFY APPROVED and user can modify or update any further details in the Application Entry screen.
If the edits are not satisfied, application will be pushed to REJECTED APPLICATIONS queue with a status update to REJECTED-PREQUALIFY REJECTED. You can also view rejected pre-qualification in the Underwriting screen.
When specific services listed in Dashboard -> System Monitor -> Services tab are 'stopped', the application status will display 'NEW PRE-SCREEN APPROVED' and user will not be able to change the status manually to move it to Underwriting queue. In such cases, services should be started post which the application is processed automatically by the system and falls in the appropriate queue as per work flow.
Using the information supplied on application, complete Applicants tab details and the following sub tab details:
The system uses information on Financial and Liabilities sub tabs to determine the applicant’s net worth. The system uses information on Employments tab and Other Incomes sub tab to calculate applicant’s debt-to-income ratio.
Note the following while completing frequency fields:
For more information, refer appendix Payment Amount Conversion.
To complete the Applicants Details screen
Oracle Financial Services Lending and Leasing can record SME business related financial information and business partners on the Business screen to assist in approving Loan application during underwriting. The Business Applicant screen is available for Loan and contains the following sub screens:
To complete the Business tab
The Business tab appears on Application Entry screen.
For details on this screen, refer Business Tab of Underwriting chapter.
Depending on the type of product you select, the following screen will be available from Requested tab
To complete Request tab:
For details on this screen refer Request Tab of the Underwriting chapter:
Depending on the type of product or producer you select, the Collateral tab opens one of the three following collateral screens: a vehicle information screen, a home information screen or an other information screen. Complete the screen that is available on your Applications screen. After that, complete the Valuation and Tracking sub screen, which the Collateral screens share. If you are entering an unsecured Loan, the Collateral tab is present but inactive; in which case, skip this step.
To enter vehicle information from the Collateral tab
To enter home information from the Collateral tab
If collateral is any other, the Collateral link displays information about that collateral.
For details on this screen, refer Collateral Tab of the Underwriting chapter.
When using the Simple Application Entry screen, you can add comments to an application at any time in the application entry process by clicking Comments tab.
To complete the Comments tab
For details on this screen, refer Comments Tab of the Underwriting chapter.
The Tracking tab enables you to record further information associated with the application. What items you choose to track are setup during implementation.
To track attributes
For details on this screen, refer Tracking Tab of the Underwriting chapter
Oracle Financial Services Lending and Leasing can be configured to automatically validate portions of an application when you attempt to change its status. The results of this data check appear on the Verification link’s Edit screen as an Error, a Warning or an Override.
If it is an Error, the system will not allow you to change application’s status and approve Loan until you fix all the errors.
If it is a Warning, the system enables you to change an application’s status without correcting the matter. While you should still investigate the problem, Warning messages are of a lesser importance than Error messages.
If it is an Override, the system displays a dialog box informing you that an override is needed; your responsibility level does not have the authority required to process this step. (Choose Yes on the dialog box to move the application to the queue of the user with the required authority.)
To validate a credit application
For details on this screen, refer Verification Tab of the Underwriting chapter.
You can enter credit application data into Oracle Financial Services Lending and Leasing Application using the Fax-In image functionality using the Fax-In container. Once the all the images are loaded into the system using the steps mentioned in ‘Entering a Credit Application’ section, you can view those images in the Fax-In container and perform data entry concurrently.
The Fax-In container option is a simple image holder which is available to the user on clicking the ‘New Application’ button. The option is available only if has been enabled in the system settings by the administrator.
If you are the administrator, you can enable/disable this feature to the users in the access screen. However, you can view the availability of this feature by navigating to Main Menu > Setup > Administration > User > Access screen. Select Screen tab and in the Security Access Definition section, the status of “ACCESS TO MENU IMAGE MAINTAINENCE” flag defines the availability of this feature. If the flag is set to ‘Y’ then the Fax-In container is available in Application Entry screen.
The image container displays the image with the header information stored in the tables loaded as a part of the loading process. You can navigate through the pictures using the navigation buttons (First, Previous, Next and Last) available on the top right.
After entering the Application details, you need to select the Image check box placed on the top of Fax Image container. By doing so the system will automatically associate the current image with the application and save it along with the other application details. Also the image will no longer be available in the container since the container only holds those images which are not associated with any application.
The Review Request tab facilitates to flag an Application for the attention of another Oracle Financial Services Lending and Leasing user and ask for review / feedback. It allows the system users to send and receive requests (including e-mail) commenting on a specific account or application. The Review Request tab supports iterative review of selected Application and also to process the review with multiple reviewers.
For detailed information on using this feature, refer to ‘Review Request’ section in Underwriting chapter of the document.
