SDK Directories
SDK directories are shown below. Note that not all listed directories may be present (or supported) in the current release.
| Path | Description |
apps
SDK based applications |
apps/linphone
Open source VoIP application utilizing TCP/TLS/DTLS/UDP for tunnel transport that has been ported to the SDK. Platform support limited to Windows, Android, and iOS. Refer to www.linphone.org for additional details. |
apps/sipp
Open source SIP traffic generator application utilizing TCP tunnel transport that has been ported to the SDK. Platform support limited to Linux. Refer to www.sourceforge.net for additional details. |
apps/tsc_sip
Reference demonstration/development guide app (tsc_sip_client.c) |
docs
SDK Documentation |
docs/html
Authoritative API HTML-based documentation. Access via “.../html/index.html” after running `make doxygen`. |
extlib
External, optional libraries |
lib
SDK Library source – to be linked with the target application |
lib/android-ndk
Android Specific library instructions and precompiled libs |
lib/CSM
tunneling Client State Machine |
lib/EIP
Embedded TCP/UDP/IP Stack |
lib/include
SDK API definitions |
lib/OSAA
Operating System Application Adaptation APIs |
lib/TAPI
Tunnel Data and Control APIs |
lib/TPL
Tunnel Control and Data Message Parsing Libraries |
tools
Development Tools |
tools/wireshark
TSCF protocol dissector |
