PreviousNextJavaScript must be enabled to correctly display this content
Download and Compile OpenSSL
The default version of OpenSSL has been removed. Developers should download the desired version of OpenSSL and modify the build script to allow on-the-fly integration with the SDK.
Download the version of OpenSSL you want to integrate into the SDK.
The customer is responsible for selecting a secure version of OpenSSL from
https://www.openssl.org/. Oracle can confirm OpenSSL version 1.0.1g works with the SDK.
In the build script for your target operating system, set the
VERSION variable to the version number of OpenSSL.
The build scripts are located in the
sdk/extlib directory and the
VERSION variable is found at the top of the script.
VERSION="1.0.1g"
If compiling version 1.0.1g for iOS, run the
patch-openssl-1.0.1g script.
./patch-openssl-1.0.1g
Run the build script for your target operating system.
