Client Private Subnet Reuse for Untrusted Segment
7.2 introduces the ability to set duplicate Virtual IPs at multiple sites when the Virtual IP Address is Private and the associated Interface Group is defined as Untrusted. This feature is intended for use is situations where multiple sites are being deployed with the same WAN link provider, with provider equipment pre-configured for the same IP address/subnet at every site.
If one or more of the duplicate Virtual IPs is not private, an Audit Error will be displayed.
