Enhanced DHCP Relay
7.2 introduces the ability for users to configure up to four DHCP server relay addresses per virtual interface, allowing users with multiple DHCP servers at their NCN site to take advantage of increased redundancy.
DHCP relays may be configured in the Advanced view of the Configuration Editor, under Sites > [site name] > DHCP > Relays, as shown below:
When configuring DHCP Relays, the Virtual Interface and Server IP 1 are required. Server IPs 2 through 4 are optional.
Monitoring information for DHCP Relay is available under Monitor > DHCP.
