New Features
The 8.2. release supports the following new features and enhancements.
Oracle Standardized Appearance
This version of the product now reflects Oracle's standard for
branding and appearance.
- ID: 19315
Oracle Enterprise Linux Support
This version of the product now relies upon Oracle Enterprise Linux.
No user interaction is required.
- ID: 19324
Oracle Standardized Versioning
The documentation and products now reflect Oracle's standard 5-digit
code for versioning. Use the following table to map from the legacy to the
current numbering scheme:
| Digit Place | Oracle Definition | Legacy Talari Definition |
| 1 | Major | Major |
| 2 | Minor | Minor |
| 3 | Maintenance Release | unused |
| 4 | Patch Set | Patch |
| 5 | Patch | Hyperfix |
For example, in legacy terms Release 8.1 P2 H1 would now be numbered 8.1.0.2.1 .
- ID: 19153
