Known Issues - SD-WAN Aware
This table lists the known issues in version 8.2.0.0.0.
| ID | Description | Severity | Found In |
| NA | NA | NA | NA |
Resolved Issues
The following issues have been fixed in this release.
| ID | Description | Found In | Fixed In |
| 30792594 | Time changes in SD-WAN Aware may not be saved after unchecking of NTP Server (Manage -> SD-WAN Aware Settings - In Date and Time). | 8.2.1.0.0 | 8.2.1.0.0 |
| 30214311 | When configuring E-Mail events with SMTP Authentication enabled, event e-mails may not be sent. | 8.2.0.0.0 |
Customer Build Notes
The following table reflects bugs fixed through the latest release.
Table 4-1 Customer Build Notes for 8.2p1
| Bug ID | Internal Release Notes |
| 30639483 | Newly added events and inventory details are unable to delete after save. |
| 30586054 | Local guest users may be displayed with no username under Manage > Users and Authentication. |
| 30571233 | Text limitations when attempting to enter a custom login message for HTTPS settings under Manage > APN Appliance Settings do not match between Aware and APN appliances. |
| 30498076 | When creating or editing a very large network map, users may experience errors editing and saving the map. |
| 30471385 | Unable to close the notification errors on the screen. |
| 30355148 | Error messages in the Configuration Editor may disappear before users can see and act on them. |
