Go to primary content
Oracle® Communications OC-CNE Installation Guide
Release 1.0
F16979-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Configure Legacy BIOS on Remaining Hosts
Prerequisites
Limitations and Expectations
References
These procedures define the steps necessary to configure additional Legacy BIOS for all hosts in OCCNE 1.0. This includes steps that cannot be performed from the HP iLO 5 CLI prompt such as RAID configuration, changing the boot mode, and setting the primary and secondary boot devices.
The procedures in this document apply to the HP iLO console accessed via KVM. Each procedure is executed in the order listed.
Procedure OCCNE Configure Addresses for RMS iLOs, OA, EBIPA is complete.
  1. Applies to HP iLO 5 only.
  2. Should the System Utility indicate (or defaults to) UEFI booting, then the user must go through the steps to reset booting back to the Legacy BIOS mode by following step: Change over from UEFI Booting Mode to Legacy BIOS Booting Mode in Table 3-6.
  3. The procedures listed here apply to both Gen10 DL380 RMSs and Gen10 BL460c Blades in a C7000 enclosure.
  4. Access to the enclosure blades in these procedures is via the Bootstrap host using SSH on the KVM. This is possible because the prerequisites are complete. If the prerequisites are not completed before executing this procedure, the enclosure blades are only accessible via the KVM connected directly to the active OA. In this case the mouse is not usable and screen manipulations are performed using the keyboard ESC and directional keys.
  5. This procedure does NOT apply to the Bootstrap Host.
Steps to Configure the Legacy BIOS on Remaining Hosts
Table 3-6 Procedure to configure the Legacy BIOS on Remaining Hosts
Step # Procedure Description
1. Expose the System Configuration Utility on a RMS Host Expose the System Utility screen to the user for a RMS host on the KVM. It does not provide instructions on how to connect the KVM as this may be different on each installation.
  1. Once the remote console has been exposed, the system must be reset by manually pressing the power button on the front of the RMS host to force it through the restart process. When the initial window is displayed, hit the F9 key repeatedly. Once the F9 is highlighted at the lower left corner of the remote console, it should eventually bring up the main System Utility.
  2. The System Utilities screen is exposed in the remote console.
2. Expose the System Utility for an Enclosure Blade
  1. The blades are maintained via the OAs in the enclosure. Because each blade iLO has already been assigned an IP address from the prerequisites, the blades can each be reached using SSH from the Bootstrap host login shell on the KVM.
    1. SSH to the blade using the iLO IP address and the root user and password. This brings up the HP iLO prompt.
      $ ssh root@<blade_ilo_ip_address>
      Using username "root".
      Last login: Fri Apr 19 12:24:56 2019 from 10.39.204.17
      [root@localhost ~]# ssh root@192.168.20.141
      root@192.168.20.141's password:
      User:root logged-in to ILO2M290605KM.(192.168.20.141 / FE80::AF1:EAFF:FE89:35E)
      iLO Standard Blade Edition 1.37 at  Oct 25 2018
      Server Name:
      Server Power: On
      </>hpiLO->
    2. Use VSP to connect to the blade remote console.
      </>hpiLO->vsp
    3. Power cycle the blade to bring up the System Utility for that blade.
      Note: The System Utility is a text based version of that exposed on the RMS via the KVM. The user must use the directional (arrow) keys to manipulate between selections, ENTER key to select, and ESC to go back from the current selection.
    4. Access the System Utility by hitting ESC 9.
  2. Enabling Virtualization
    This procedure provides the steps required to enable virtualization on a given Bare Metal Server. Virtualization can be configured using the default settings or via the default Workload Profiles.
    Verifying Default Settings
    1. Expose the System Utility by following step 1 or 2 depending on the hardware being configured.
    2. Select System Configuration
    3. Select BIOS/Platform Configuration (RBSU)
    4. Select Virtualization Options
      This view displays the settings for the Intel(R) Virtualization Technology (IntelVT), Intel(R) VT-d, and SR-IOV options (Enabled or Disabled). The default values for each option is Enabled.
    5. Select F10 if it is desired to save and stay in the utility or select the F12 if it is desired to save and exit to continue the current boot process.
3. Change over from UEFI Booting Mode to Legacy BIOS Booting Mode
  4. Select Boot Options.
    This menu defines the boot mode.
    If the Boot Mode is set to UEFI Mode then continue this procedure. Otherwise there is no need to make any of the changes below.
  5. Select Boot Mode
    This generates a warning indicating the following:
    Boot Mode changes require a system reboot in order to take effect. Changing the Boot Mode can impact the ability of the server to boot the installed operating system. An operating system is installed in the same mode as the platform during the installation. If the Boot Mode does not match the operating system installation, the system cannot boot. The following features require that the server be configured for UEFI Mode: Secure Boot, IPv6 PXE Boot, Boot > 2.2 TB Disks in AHCI SATA Mode, and Smart Array SW RAID.
    Hit the ENTER key and two selections appear: UEFI Mode(highlighted) and Legacy BIOS Mode
  6. Use the down arrow key to select Legacy BIOS Mode and hit the ENTER. The screen indicates: A reboot is required for the Boot Mode changes.
  7. Hit F12. This displays the following: Changes are pending. Do you want to save changes? Press 'Y" to save and exit, 'N' to discard and stay, or 'ESC' to cancel.
  8. Hit the y key and an additional warning appears indicating: System configuration changed. A system reboot is required. Press ENTER to reboot the system.
    1. Hit ENTER to force a reboot.
      Note: The boot must go into the process of actually trying to boot from the boot devices using the boot order (not just go back through initialization and access the System Utility again). The boot should fail and the System Utility can be accessed again to continue any further changes needed.
    2. After the reboot, hit the ESC 9key sequence to re-enter the System Utility. Selecting System Configuration->BIOS/Platform Configuration (RBSU)->Boot Options. Verify the Boot Mode is set to Legacy Boot Mode UEFI Optimized Boot is set to Disabled
  9. Select F10 if it is desired to save and stay in the utility or select the F12 if it is desired to save and exit to complete the current boot process.
4. Force PXE to boot from the first Embedded FlexibleLOM HPE Ethernet 10Gb 2-port Adapter
  2. Select System Configuration.
  3. Select BIOS/Platform Configuration (RBSU) .
  4. Select Boot Options. This menu defines the boot mode.
  5. Confirm the following settings: Boot Mode Legacy BIOS Mode UEFI Optimized Boot , and Boot Order Policy Retry Boot Order Indefinitely(this means it keeps trying to boot without ever going to disk). If not in Legacy BIOS Mode, follow procedure 2.1 Change over from UEFI Booting Mode to Legacy BIOS Booting Mode.
  6. Select Legacy BIOS Boot Order In the default view, the 10Gb Embedded FlexibleLOM 1 Port 1 is at the bottom of the list.
  7. Move the 10 Gb Embedded FlexibleLOM 1 Port 1 entry up above the 1Gb Embedded LOM 1 Port 1 entry. To move an entry press the '+' key to move an entry higher in the boot list and the '-' key to move an entry lower in the boot list. Use the arrow keys to navigate through the Boot Order list.
  8. Select F10 if it is desired to save and stay in the utility or select the F12 it is desired to save and exit to continue the current boot process.
5. Enabling Virtualization
This procedure provides the steps required to enable virtualization on a given Bare Metal Server. Virtualization can be configured using the default settings or via the Workload Profiles.
6. Disable RAID Configurations
OCCNE does not currently support any RAID configuration. Follow this procedure to disable RAID settings if the default settings of the System Utility include any RAID configuration(s).
Note: There may be more than one RAID Array set up. This procedure should be repeated for any RAID configuration.
  3. Select Embedded RAID 1 : HPE Smart Array P408i-a SR Gen 10.
  4. Select Array Configuration.
  5. Select Manage Arrays.
  6. Select Array A (or any designated Array Configuration if there are more than one).
  7. Select Delete Array. A warning is displayed indicating the following:
    Deletes an Array. All the data on the logical drives that are part of deleted array will be lost. Also if the deleted array is the only one on the controller, the controller settings will be erased and its default configuration is restored.
  8. Hit ENTER, the changes are submitted and Delete Array Successful is displayed.
  9. Hit ENTER to go back to the main menu for the HPE Smart Array.
  10. Select F10 if it is desired to save and stay in the utility or select the F12 it is desired to save and exit to continue the current boot process.
7. Enable the Primary and Secondary Boot Devices
This steps provide necessary to configure the primary and secondary bootable devices for a Gen10 Server.
Note: There can be multiple configurations of hardware drives on the server that include both Hard Drives (HDD) and Solid State Hard Drives (SSD). SSDs are indicated by SATA-SSD ATA in the drive description. The commands below include two HDDs and two SSDs. The SSDs are not to be selected for this configuration. The actual selections may be different based on the hardware being updated.
  4. Select Set Bootable Device(s) for Legacy Boot Mode.
    If the boot devices are not set then Not Set is displayed for the primary and secondary devices.
  5. Examine the list of available hardware drives. If one or more HDDs are available, continue with this procedure.
    Note: A single drive can be set as both the primary and secondary boot device but that is not part of this configuration.
  6. Select Bootable Physical Drive
  7. Select Port 1| Box:3 Bay:1 Size:1.8 TB SAS HP EG00100JWJNR. Note: This example includes two HDDs and two SSDs. The actual configuration may be different.
  8. Select Set as Primary Bootable Device.
  9. Hit ENTER.
    Note: There is no need to set the secondary boot device. Leave it as Not Set.
  10. Hit the ESC key to back out to the System Utilitiesmenu.
  11. Select F10 if it Is desired to save and stay in the utility or select the F12 if it Is desired to save and exit to continue the current boot process.
