| Oracle® Communications Network Exposure Function (NEF) Cloud Native Installation and Upgrade Guide Release 1.0 F16986-01 |
![]() Previous |
![]() Next |
The Network Exposure Function requires a MySQL database to store the configuration and run time data.To deploy the NEF:
ocnef-pkg-1.0.0.0.0.tgz |_ _ _ _ _ _ ocnef-1.0.0.tgz (helm chart) |_ _ _ _ _ _ ocnef-images-1.0.0.tar (docker images) |_ _ _ __ _ Readme.txt (Contains cksum and md5sum of tarballs)
Check the checksums of tarballs mentioned in the Readme.txt file.
to docker and push imported docker images to user docker registry.
docker load --input /<IMAGE_PATH>/ocnef-images-1.0.0.tar docker tag ocpcf/nef_asqos:1.0.0 <customer repo>/nef_asqos:1.0.0 docker push <customer repo>/nef_asqos:1.0.0 * Repeat above tag and push commands for ALL imported docker images as listed in the Table 2-1
User may need to configure docker certificate to access customer registry via HTTPS. Configure the certificate before executing the docker push command or the command may fail to execute.
Table 2-1 provides the details of the docker images file name:
Table 2-1 Docker Images
| Service Name | Docker Image Name | Service Category |
| DB Service | db-service | Common |
| Nrf Client Service | nrf_clientservice | Common |
| CM Service | ocpm_cm_service | Common |
| Performance Monitoring Service | perf_info | Platform |
| Config Server Service | ocpm_config_server | Common |
| Asqos Service | nef_asqos | NEF |
| Nef Me Service | nef_me | NEF |
| Capif Core Service | capif_core | NEF |
| Application Info Service | app_info | Platform |
| Readiness Check | readiness-detector | Common |
| Oracle Linux 7 with JDK11 | ocpm_ol7_jdk11 | Common |
Table 2-2 provides the information about the modules:
Table 2-2 Module Descriptions
| Module Name | Description |
| common | Common service module which would be shared by separate NF as supporting service, such as GUI, and API Gateway. |
| platform | Platform service to provide monitoring services, also shared by separate NF. |
| nef | Define NEF services. |
It is mandatory to run the below command under helm chart folder
as the last line of the command,
./<HELM_CHART_NAME_WITH_EXTENSION>
specifies that helm chart path is current working path. To run the below
command in another server, copy the helm chart file to it first.
helm install
--namespace=<NAMESPACE>-nef --name=<NAME>-nef \
--set
global.envMysqlHost=<MYSQL_HOST>,global.envMysqlUser=nefusr,global.envMysqlPassword=nefpasswd
--set
global.envJaegerAgentHost=<JAEGER_SERVICE>.<JAEGER_SERVICE_NAMESPACE>
--set
global.envManageNF=NEF,global.envSystemName=NEF,common.configmapApplicationConfig.nrfClientType=NEF
--set
global.imageTag=<IMAGE_TAG>,global.dockerRegistry=<DOCKER_REGISTRY_ADDRESS>
--set
platform.enabled=true,pcf.enabled=false,bsf.enabled=false,common.enabled=true,nef.enabled=true
--set
common.deploymentNrfClientservice.envNamespace=<NAMESPACE>-nef,platform.appinfo.topic=NRF.UDM
Table 2-3 provides details of each variable:
Table 2-3 Variables Description
| Variable | Description | Notes |
| <NAMESPACE> | Deployment NF namespace used by helm command | |
| <NAME> | Deployment NF name used by helm command | |
| <MYSQL_HOST> | MySQL host name or IP address | global.envMysqlUser and global.envMysqlPassword variables in above command from database section configured in previous step |
| <JAEGER_SERVICE> <JAEGER_SERVICE_NAMESPACE> | Both parameters could be found in same Kubernetes cluster | Follow the below format:
For example, consider OCCNE. Run the command,
to get all services under namespace, occne-infra. Consider *-jaeger-agent as jaeger service name, such as occne-tracer-jaegeragent.occne-infra, then the jaeger agent service name under jaeger deployment is occne-tracer-jaeger-agent. Example: occne-tracer-jaegeragent.occne-infra |
| <IMAGE_TAG> | The image tag used in customer docker registry, it is recommend
to use same image tag when pull docker image to registry.
If follow above steps to push docker image to customer docker registry then the <IMAGE_TAG> value should be 1.0.0 |
Each service deployment yaml file would use global.imageTag as image tag to fetch relateddocker image per helm chart design. With the release tar file, the global image tag for all services is 1.0.0 |
| <DOCKER_REGISTRY_ADDRESS> | Customer docker registry address | If registry has port value, add port. For example, reg-1:5000 |
NEF Services deployment service type. Kubernetes provides the following three deployment types.
Table 2-4 Service Deployment Service Type
| Service Type | Description |
| ClusterIP |
Exposes the service on a cluster-internal IP. Choosing this value makes the service only reachable from within the cluster. This is the default ServiceType |
| NodePort |
Exposes the service on each Node's IP at a static port (the NodePort). A ClusterIP service, to which the NodePort service routes is
automatically created. Contact the NodePort service from outside the cluster,
by requesting,
Most of the NEF services use NodePort to deploy. |
| LoadBalancer |
Exposes the service externally using a cloud provider's load balancer. NodePort and ClusterIP services, to which the external load balancer will route, are automatically created. Given latest OCCNE already integrated METALLB, configure IP address to MetalLB on OCCNE. Note: For user interface page and API gateway service, it is mandatory to use loadBalancer type. Assuming that OCCNE is integrated with MetalLB, configure IP address to MetalLB on OCCNE. |
