| Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide Release 1.0 F16981-02 |
![]() Previous |
![]() Next |
This section describes about the NRF customization.
The NRF deployment is customized by overriding the default values of various configurable parameters.
Customize the yaml file
ocnrf-custom-values-1.0.0.yaml
as per the required parameters.
The
template can be downloaded from OHC.
Download the package
Network Repository
Function (NRF) Custom Template and Unzip to get
file.
Sample content of ocnrf-custom-values-1.0.0.yaml
file, refer section,
NRF Installation.
# Copyright 2018 (C), Oracle and/or its affiliates. All rights reserved.
# This yaml file could be supplied in helm install command when deploying OCNRF v1.0.0
# helm install ocnrf/ --name ocnrf --namespace <namespace> -f <this file>
# Compatible with OCNRF CHART VERSION 1.0.0
# I.
# AND
# set the hostname and port number of the primary sql node in
# nfregistration.mysql.primary.host
# nfregistration.mysql.secondary.host
# nfregistration.mysql.port
# nfsubscription.mysql.primary.host
# nfsubscription.mysql.secondary.host
# nfsubscription.mysql.port
# nrfauditor.mysql.primary.host
# nrfauditor.mysql.secondary.host
# nrfauditor.mysql.port
# nfdiscovery.mysql.primary.host
# nfdiscovery.mysql.secondary.host
# nfdiscovery.mysql.port
# II.
# - To configure SPF as outbound proxy in NRF,
# set the SPF worker's k8s service name (<servicename>.<namespace> or <complete fqdn> and port in
# nfsubscription.http.proxy.host
# nfsubscription.http.proxy.port
# III.
# - To increase NF heartbeat timer
# (when working with NFs/Simulators that are not capable of sending heartbeat),
# set the duration following the convention (s)econds, (m)inutes, (h)ours, d(ays)
# e.g. 10m, 2h, 1d, etc. in
# nfregistration.nf.heartbeat.duration
# nrfauditor.nf.heartbeat.duration
nfregistration:
image:
repository: ocnrf/ocnrf-nfregistration
pullPolicy: IfNotPresent
mysql:
primary:
host: "ocnrf-mysql"
secondary:
host: "ocnrf-mysql"
port: 3306
nfsubscription:
image:
repository: ocnrf/ocnrf-nfsubscription
mysql:
primary:
host: "ocnrf-mysql"
secondary:
host: "ocnrf-mysql"
port: 3306
http:
proxy:
host:
port: 80
nrfauditor:
image:
repository: ocnrf/ocnrf-nrfauditor
mysql:
primary:
host: "ocnrf-mysql"
secondary:
host: "ocnrf-mysql"
port: 3306
nf:
heartbeat:
duration: "90s"
missAllowed: 3
suspend:
duration: "7d"
nfdiscovery:
image:
repository: ocnrf/ocnrf-nfdiscovery
mysql:
primary:
host: "ocnrf-mysql"
secondary:
host: "ocnrf-mysql"
port: 3306
disc:
result:
profiles:
loadThreshold:
ambassador:
fullnameOverride: ocnrf-endpoint
image:
repository: ocnrf/ocnrf-ambassador
tag: 0.50.3
ambassador:
service:
type: LoadBalancer
annotations :
metallb.universe.tf/address-pool: signaling
getambassador.io/config: |
apiVersion: ambassador/v1
kind: Module
ambassador_id: ambassador-ocnrf
config:
service_port: 8080
