| Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide Release 1.0 F16981-02 |
![]() Previous |
![]() Next |
This chapter contains information about the NRF Installation in Cloud Native Environment.
Pre-installation Procedure
Create Database User/Group
The NRF uses a MySQL database to store the configuration and run time data.
This procedure must be performed only once before initiating the NRF deployment.CREATE USER '<username>'@'%' IDENTIFIED BY '<password>'; DROP DATABASE if exists nrfdb; CREATE DATABASE nrfdb CHARACTER SET utf8; GRANT SELECT, INSERT, CREATE, ALTER, DROP, LOCK TABLES, CREATE TEMPORARY TABLES, DELETE, UPDATE, EXECUTE ON nrfdb.* TO '<user>'@'%'; USE nrfdb;
The<username> and
<password> is
created by the Database Administrator.
CREATE TABLE `NfInstances` (
`nfInstanceId` varchar(36) NOT NULL,
`nfType` varchar(30) NOT NULL,
`nfStatus` enum('REGISTERED','SUSPENDED') NOT NULL,
`doc` json NOT NULL,
PRIMARY KEY (`nfInstanceId`)
) ENGINE=NDBCLUSTER DEFAULT CHARSET=utf8;
CREATE TABLE `NfSubscriptions` (
`subscriptionId` varchar(36) NOT NULL,
`nfStatusNotificationUri` varchar(256) NOT NULL,
`validityTime` datetime NOT NULL,
PRIMARY KEY (`subscriptionId`)
CREATE TABLE `NfStatusMonitor` (
`lastHbTimestamp` datetime DEFAULT NULL,
`lastNotifLoad` int(11) DEFAULT NULL,
`nfLoad` int(11) DEFAULT NULL,
`numHbMissed` int(11) NOT NULL,
`suspendedTimestamp` datetime DEFAULT NULL,
NRF Deployment on Kubernetes
By default, the namespace and helm release for NRF isocnrf.
Table 3-4 NRF Deployment
| Step # | Procedure | Description |
1
Create customized
ocnrf-custom-values-1.0.0.yaml
file
Create the customized
with the required input parameters.
To configure the parameters, see section NRF Configuration. or,The
Download the Network Repository Function (NRF) Custom
Template. Unzip the
2
Go to the unzipped OCNRF package |
Go to the unzipped OCNRF package in the following directory:
3
Deploy OCNRF | Execute the following command:
For example:
4
Check status of the deployment | Execute the following command:
For example:
5
Check status of the services | Execute the following command:
For example:
If
6
Check status of the pods | Execute the following command:
Status column of all the pods should be 'Running' Ready column of all the pods should be n/n, where n is number of containers in the pod. For example:
NAME READY STATUS RESTARTS AGE ocnrf-endpoint-6cb48bdc57-s6vws 2/2 Running 0 18h ocnrf-mysql-5d695b599f-5gwhh 1/1 Running 0 18h ocnrf-nfdiscovery-6c4b69c97f-sc84n 1/1 Running 0 18h ocnrf-nfregistration-6bcf5d84b7-qfrjm 1/1 Running 0 18h ocnrf-nfsubscription-67c6cc8fff-gtldj 1/1 Running 0 18h ocnrf-nrfauditor-77d57949c7-gx2p2 1/1 Running 0 18h |
Table 3-5 Parameters and Definitions for NRF Installation
| Parameters | Definitions |
<helm-release>
It is a name provided by the user to identify the helm deployment |
<k8s namespace>
It is a name provided by the user to identify the kubernetes namespace of the OCNRF. All the OCNRF micro services are deployed in this kubernetes namespace. |
