| Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide Release 1.0 F16981-02 |
![]() Previous |
![]() Next |
This section includes information about upgrading an existing NRF deployment.
When you attempt to upgrade an existing NRF deployment, the running set of containers and pods are replaced with the new set of containers and pods. However, If there is no change in the pod configuration, the running set of containers and pods are not replaced.
ocnrf-custom-values-1.0.0.yaml
file with new values.
It is advisable to create backup of the file before changing any configuration.To configure the parameters, see section NRF Configuration
Execute the following command to upgrade an existing NRF deployment:
helm upgrade
<release> -f ocnrf-custom-values-1.0.0.yaml
Table 4-1 Parameters and Definitions during NRF Upgrade
| Parameters | Definitions |
<chart>
It is the name of the chart that is of the
form
<repository/ocnrf>.
For example:
reg-1/ocnrf
or cne-repo/ocnrf
<release>
It can be found in the output of
helm
list command
helm history
<helm_release>
helm rollback
<release name> <revision number>
