| Oracle® Communications Network Slice Selection Function (NSSF) Cloud Native Installation Guide Release 1.0 F16982-02 |
![]() Previous |
![]() Next |
This section informs about the sequence in which NSSF must be installed.
Table 3-1 Installation Sequence
| Sl.No | Phase | Description |
| 1 | Installation Preparation | Download the required files and load the files to the system. |
| 2 | Configure custom_values.yaml file. |
This includes configuring the following based on the deployment:
Note: Other configurations might be changed based on the deployment. |
| 3 | NSSF deployment | NSSF can be deployed in either of the following
ways:
| 4 | Verify NSSF deployment | Check if the services and pods are up and running. |
NSSF Images
Following are the NSSF images:
Table 3-2 NSSF Images
| Services | Image |
| ocnssf-nsconfig | ocnssf-nsconfig |
| ocnssf-nspolicy | ocnssf-nspolicy |
| ocnssf-nsregistration | ocnssf-nsregistration |
| ocnssf-nsselection | ocnssf-nsselection |
