| Oracle® Communications Network Slice Selection Function (NSSF) Cloud Native Installation Guide Release 1.0 F16982-02 |
![]() Previous |
![]() Next |
The following procedure describes the steps to download the NSSF Images and Helm files from OSDC.
Table 4-1 NSSF Installation Preparation
| Step | Procedure | Description |
1
Download the NSSF package file |
Customers are required to download the NSSF package file from Oracle Software Delivery Cloud (OSDC). Package is named as follows: <nfname>-pkg-<marketing-release-number>
2
Untar the NSSF Package File |
Untar the NSSF package to the specific repository: tar -xvf <<nfname>-pkg-<marketing-release-number>> The package file consists of following:
3
Check the checksums | Check the checksums of tarballs mentioned in
Readme.txt. Refer to
the
Readme.txt file for
commands and checksum details.
4
Load the tarball to system |
Execute the following command to push the Docker images to docker registry: docker load --input ocnssf-images-1.0.0.tar |
5
Check if all the images are loaded |
Execute the following command to check: docker images Refer table NSSF Images in section NSSF Installation Sequence for the list of images. |
6
Push docker images to docker registry |
Execute the following commands to push the docker images to docker registry:
7
Untar Helm Files |
Untar the helm files: tar -xvzf ocnssf-1.0.0.tgz |
8
Download the Native Network Slice Selection Function (NSSF) Custom Template ZIP file |
Download the Native Network Slice Selection Function (NSSF) Custom Template ZIP file from OHC:
