Project managers need a way to view team member status updates before the updates are committed to the schedule. The team member status updates feature enables you to view, update, approve and reject activity progress captured by users of the P6 Team Member interfaces.
When setting up team member status reviews in Project Preferences, you enable reviews for the project, choose the required reviewers, choose the review type, and choose whether to require reviews for all activity updates in the project. Status updates can be turned on and off for individual activities on the Activities page. In addition to setting reviewers for all activities, you can set reviewers for all activities within a specific WBS on the Activities page. The assigned status reviewers, or a user with Admin or Project superuser privileges can view, edit, approve and reject the status updates for the project.
When a team member assigns an activity or saves a change in a P6 Team Member interface, the change appears in the Status Updates page.
The history of all activity updates made in P6 Team Member interfaces is captured in the Update History detail window on the Activities page.
