Configuring P6 Team Member Status Update Reviews
Configure the team member status updates feature to enable a project manager to manually edit and approve status updates made by P6 Team Member interface users before the updates are applied to the project.
Note: The status update reviews feature is turned off by default.
To configure status updates:
  1. Click Projects.
  2. On the Projects navigation bar, click EPS.
  3. On the EPS page:
    1. Select a project or EPS node.
      Note: If an EPS node is selected, the data shown represents the default settings for the fields. These defaults and the selections you make in any fields will be applied to all projects which match the applied filter in the selected EPS node and all child nodes.
    2. Click Row Actions and select Set Project Preferences.
    3. In the Project Preferences dialog box, click Team Member.
    4. On the Team Member page, click Status Reviews.
    5. On the Status Reviews tab:
      • Select Enable review for team member status updates.
      • Select Review required by default for new activities if all new activities require approval. When prompted to apply the setting to all existing activities in the project, choose Yes or No.
      • In the Review Type list, select whether anyone can or everyone must review status updates.
      • In the Reviewers list, click Select.
    6. In the Select Status Reviewers dialog box:
      • Select people to review activity status updates.
      • Click Select.
      • When prompted to set this user as the status reviewer for all WBS nodes in the project, choose Yes or No.
    7. Click OK.
Tips
Related Topics
About P6 Team Member Status Updates
Working with P6 Team Member Status Updates
Assigning a Status Reviewer to a WBS
Selecting an Activity for Review
Reviewing Team Member Status Updates
Viewing Team Member Status Updates History
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
