Creating Projects
Create projects to define a set of activities and WBSs that work toward a common goal.
To create a project:
  1. Click Projects.
  2. On the Projects navigation bar, click EPS.
  3. On the EPS page:
    1. Select the EPS element to which you want to add the new project.
    2. Click Row Actions and select Add Project.
    3. In the Add Project dialog box:
      • Click the General tab and select an option or enter a value in each required field.
        Notes: Avoid using the pipe character ( | ), or brackets ( < or > ) in the Project Name.
    4. Click Create.
Tips
Related Topics
About Projects
Creating Projects from Existing Projects or Templates
Creating Project Templates from Existing Projects or Templates
Deleting Projects or EPS Elements
Customizing Detail Windows
Configuring Project Preferences
Opening Projects or Templates
Cutting, Copying, and Pasting Data
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
