Export and email an XER project
- Open the project you want to export and email.
- Choose File, Send Project.
The application creates an XER export file, automatically opens your email system, and attaches the XER file to the body of the email message. The subject line of the email is automatically populated with the name of the project.
- Enter the email address and send the email.
Notes
- If an email system is not present on your computer, the application will launch the Create a Mail Profile wizard. You can choose to create a mail profile, or click Cancel to exit. If you click Cancel, you cannot email the XER file; the file will remain in your local Temp directory.
- This feature applies to XER files only.
