Use the Assign Resources by Role dialog box to assign a resource to the selected activity according to the resource's assigned roles.
Display Options bar: Click to change the table’s fonts and colors, filter the display, or group the display by resource codes.
Search: Type a resource ID or name to display a filtered list of resources whose ID or name begins with this value.
Resource ID: Lists IDs for resources with role assignments that correspond to the selected activity's role assignments.
Resource Name: Lists names of resources with role assignments that correspond to the selected activity's role assignments.
Proficiency: Lists each resource's proficiency for the selected activity's assigned role.
Max Units/Time: Lists the selected resource's availability, or the maximum amount of work units the selected resource can perform in a single work period, according to effective date.
Assign: Assigns the selected resource to the selected activity.
Remove: Removes the selected resource from the selected activity.
Tip
- To sort the display, click a column label.
Note
- If resource security is enabled, you can only select resources from under the resource root node you have access to or from current project resources.
