- Choose Project, WBS.
- Select the WBS element whose earned value settings you want to define, then click the Earned Value tab.
- In the Technique for Computing Performance Percent Complete area, choose the completion percentage method you want to use when calculating an activity's earned value.
- In the Technique for Computing ETC (Estimate-to-Complete) area, choose the method you want to use when calculating an activity's Estimate to Complete (ETC) value.
